Diff Problem
Iv diff at home for my coupe although i require a Crown Wheel and Pinion for it the teeth are stripped of the both crown & pinion. Can anyone help? Or would anyone know where i could get a hold of these parts?
I have a extra crown wheel and pinion but I am loking for a set of 86/87 half shafts. Do you have any? Want to do a deal?
:D
rikard
www.stageoneimports.com does Techno Pro Spirits Crown and Pinion i think, you can buy any ratio you like. 4.3 is stock btw.
Paz
AE86DRIFTO, I COULD GET YOU A SET OF SHAFTS FOR HER THERE THE THICKER SHAFT COMPARED TO THE 84 MODEL ARENT THEY? I KNOW WHERE THERE IS A PAIR OF SHAFTS THAT A MATE HAS SPARE. STRAIGHT SWAP?
WHAT RATIO IS THE CROWN WHEEL & PINION? ANY BROKEN TEETH OR MARKS ON THEM?
THE ONLY PROBLEM IS IM IN NORTHERN IRELAND. AND UR IN UK/BELGUIM
If you could get a set of shafts that would be great. Straight swap sounds great!
I do not know what ratio the crown wheel and pinion is, will have to check. Came out of a 85 LSD, wll probably be stock ratio.
Do your half shafts have bearings?
E mail me so we can talk as soon as possible! :D
Rikard
AE86DRIFTO as far as i know the bearing and all should be on it but will find out for you over the weekend.
MY EMAIL ACCOUNT IS coupecircles@hotmail.com.
Hi
I tried to e mail you but your e mail is not working, it says the email addy does not exist!
sorry forgot to add a bit of it in:- coupecircles123@hotmail.com
coupecircles - If you can get any more late halfshafts, I desperately need a pair or even just a single one if that's all that's available.
Thanks.
