Boot measurements Yaris cross
Speedster123
Please can someone help me with boot measurements length and width maximum height to roof of car thanks?
I think you might need to be more specific.
Seats folded or upright?
The maximum height over what length?
The minimum height from boot floor to hatch frame might be better.  You can remove the upper boot floor which will I increase the depth.
What are you thinking of getting in?
Roy124
seats folded please
height from boot floor to lowest point of roof line
boot floor at highest position due to I need fit two wheelchairs I need to fit they don’t fold but I know the chair measurements so that’s why I need car boot measurements as it’s tricky to take all kit to dealership.
I will try and get some measurements tomorrow.  I think the flat load bay is what you need.  Removing the upper boot floor might help but only over part of it.
Here goes.  It is a complex shape but we have load length of 59in/150cm and a minimum height of 28/71.  The minimum width between wheel arch is 36/93 but at 12/31.5 higher the width is 42/107.
Ahead of the wheel arch obstruction you have 50/129 width between doors and about 29/73 depth.
Hope that helps.
  • Thanks 2
