Toyota Tilt Sensor - Can't find link on Toyota site
Bruce Lea
1 hour ago, Bruce Lea said:
Should I get a tilt sensor fitted, does it fit to the factory fitted imboliser?
Here is the link for the Toyota tilt sensor system.
How much does it cost fitting?  Do you get a separate key fob?
the cost including the parts and fitting was £50, an alarm status indicator with a small button for deactivating the alarm was fitted at the front central console , when the engine is switched off, the tilt alarm is automatically activated, you don't need a separate key to control it, you will get an unique security code for permanently disabling and reactivating the alarm as well.
This can be fitted to the factory fitted immobiliser on the car? So £50 Inc fitting from Toyota min dealer, sounds ok
