Park assist malfunction
Jan2603
Hi
Had argument with deer. Front bumper damaged and one parking sensor not working.
It will be a few weeks before vehicle is repaired but how do I get rid of the warning on the display. Local dealer says not possible, any ideas?
RAV 4 hybrid 2021.
mike
Assuming that you are talking about a warning message on the MID (obscuring more useful stuff) can you not simply press the 'return' button on the steering wheel to indicate that you have read the message?
You'd need to do so at least every time you started the car but that is perhaps better than nothing ...
Tried and this works for a couple of seconds. Better than nothing though!
mike
Hi Philip thank you for your help.
I have tried that but after a few seconds it goes back to the warning message.
Turning the park assist off has worked thank you.  My local Toyota dealer told me that wasn’t possible but managed to do it with the help of Google.  Thank you for the advice
Doesn't work. Removes the message for seconds then returns. As infinitum. Happened to me with the radar cruise control in some light snow. Malfunction warning. Which carried on until I had to pull into services tens of miles later where I switched the car off and back on again. That fixed it but that was for a temporary malfunction caused by the snow.
