Can anyone assist please and tell me if the Corolla GR Sports Touring 2021 headlamps are adjustable for European driving or is it a case of reverting to the normal stick on Eurolites beam deflectors.
Any takers to help me with this one please
Thanks 😀
I can’t help with exact answer however been discussed previously and some owners had used stickers but most have not used anything or tried to convert  the lights to eu standard as what I understood these type of lights has different light pattern from halogen bulb lights and doesn’t need to have any modifications to be legal to drive in Europe. The owners also mentioned that no one has ever flashed at them to warn them up they are blinded by their car lights . 👍
Do you know what sort of lights you have?
If they're LEDs they're probably projector-type and won't need beam deflectors. On the current Toyotas, generally cars with halogens will need beam deflectors but ones with LEDs tend to be projector type and have a flat light pattern and don't need them.
A quick and dirty way to check is to park in front of a flat surface and just turn on the dipped beams - If the beam pattern is very flat, you're okay; If it illuminates much higher up on the left side then you'll need the beam deflectors.
Thank you both for your replies.
They are LED so i'll try against the garage door.
