Toyota Rav4 2.2 d-cat 2006
Doni D
Hey there,
I recently buyed a used Toyota rav4 2.2 d-cat 2006 and after 2 months of using it showed me an engine problem, i was at the mechanic and it scaned the car and said that i need to change EGR and  O2 sensor,  i changed those but it still didnt work, i went and did EGR off and DPF off,  the lights went off but the engine has no power.
Can someone help me what to do or has anyone had this problem ?
Almost everyone who has a vehicle with that engine has had the same or similar problem.
I've yet to read a definitive cure.
Good luck.
I had a 2006 rav T180 for about 8 months with no problems . However previous to that I was going to buy the same model from a dealer that I know well. That particular T180 had running problems ie: engine management light illuminated, check 4X4 system etc they sent it  to a diesel specialist turned out it was the injectors so as Iain has said could be them. Did the engine have power before the egr and dpf replacement? Toyota had lots of problems with that engine up until approx 2008.
Yes, its the model with 177hp and it had enough power, but now it looks like an engine with 75hp hahah
On 10/2/2022 at 7:20 PM, Hybrid21 said:
Have you checked the injectors Doni ?
No i haven't checked them, before i did egr and dpf off i changed a part i think it was like second egr (that's what the mechanic said)
Good luck.
Please if you find anything let me now, im stuck like this for more than 2 months and it sucks.
