Avensis 2.0 2007 (1AZ-FSE) T25 gasoline smell when idle?
ulflun
Since some weeks ago it started to smell petrol/gasoline when idle/stops at red lights etc. I've made a quick view under the hood but can not see any obvious. Also looked in the back under the seat at the pump, but no obvious leak either.
Under the hood I've just taken the main motor protection cover off but I can not see any obvious here either.
Is there any common issues for T25 here to look at? Injector leaks? Please help!
The last time I smelt a paraffin type odour the EGR valve failed within a couple of weeks ,mine was a diesel engine.
