ok give me a few mins
9 minutes ago, flash22 said:
Look at the diagram !!
Original
2nd method
So 2nd method just does the P/S light. It constant flash
1st test no difference
Are you sure you have the correct pins
yeah. used the one the diagram said to use
That's really odd - you need a scan tool to see if it can talk to the ecu and/or the ABS
at the moment i do that have a scan tool.
Just triple checked its TC and CG the ABS light should stay solid then flash
try removing the link after you turn the ignition on
Ok how do i know if it tc and cc?
By the diagram above that shows TC an CG
So here are picts20221013_130153.thumb.jpg.eeab21562356284e682d453753a8933c.jpg20221013_130204.thumb.jpg.3da191aee06f053dbff7c57d3e15abd7.jpg
Yes that's correct
Yes
So i try and get a libe data obd reader
