Airbag light flashing and the code is b1000
Elim
I need help with this one .  I have aygo 2006 and I got the car since 2018 and the Airbag light came on last month i did clear the code, but it came back on after 2 weeks .
B1000 airbag ecu malfunction .
Can anyone tell me how to fix this problem?
thanx in advance
3 main issues which can do this
Faulty ecu
ecu harness is open/short
Ecu circuit poor connection (corrosion on pins, bent pins)
Check connector under pass seat it can come loose after while
its a known issue on the early cars, more than likely an SRS ecu issue £40-70 used - check the part number of the unit in the car (lives under the centre console) and post it here as there may be an updated version
as long as it has no crash data, its plug and play. It has to be the same part number or the one i posted above
