hi, I seriously need help, I got a corolla verso from 2003 and would really like to have some other system in it, such as a 2-din radio of some kind, that's the easy part, but I also found a frame for it, but it dont fit....does anyone have an idea or knowledge of what the hell I should do here since it doesn't fit the sides and the fastening is only at the bottom and not at the top like the original .......
( i live in denmark)
no i have not and that you are showing is from the 04 model
looks the one you have is for the corolla, did you get the brackets with it ?
yes there are these and i cant se how in the world they are going to fit
so again i dont know what to do and all the frames i found for it are the same
They are for the standard corolla (non verso)
see my above post
yes thanks for the links i just wish i could se the outside mesurements for the frames
it dont fit mine because i dont have buttons over the radio
There is a factory trim you can use 55417-13010 then you need a double din adapter to suit  eg. CT24TY43
it's a very old thread, don't post on it
