Starting issues 2007 Rav4
Cressbrook
Hi every one I've recently acquired a 2007 rav4 2.2d4d xtr my issue is I go to turn it on it starts up then dies but does not show any fault codes, however if I disconnect and reconnect the Battery it will start no problem then I can drive round go to the shop and it'll start but if I leave it 20 minute or more I have to do the Battery again I've replaced fuel filter and suction control valve and had the key reprogrammed,Has any one else had this issue and a possible solution as it is driving my wife mad having to keep opening the bonnet to go out thank you on advance.
