Charging phone
Coco89
Is there anyway you can charge your phone with your ignition off? Their was a way to do it on my mk7.5 gti golf where one of the fuses was moved along one space and kept it live
Why the need as the Phone will charge rapidly once the car starts even if you are using ACP.
Tel
Don't think it's possible.
Just be more prepared by charging the night before indoors. Whenever I'm in the car, it's usually for a few hours due to work and charged it fully most of the time.
Yes it is possible if you can find a permanently live output on the fuse gang or take a live feed from the Battery. Not something I would do though as, as has been said already, the phone will charge quickly anyway.
I use a QuadLock case for my iPhone and installed the QuadLock dash mount for it with the MAG charger built in. That is plugged into the USB socket and the wire is more or less hidden. It all looks neat a discrete. The mount is on my right side above the air vent. The phone charges quickly. I can charge it from the Qi pad in the central console but rarely bother.
Charge a powerbank whenever you drive.
Connect it to your phone when the ignition is off.
