2010 toyota avensis 2010 Front nearside suspension arm removal
Johnnya260180
I am having trouble removing nearside front suspension arm on my toyota avensis 2010 plate there's one bolt that can't come out due to automatic gearbox oil sump being in the way I was going to remove sump is it easier to remove engine mount bolts and jack it up thanks for any advice
Yes, you will need to undo transmission mount bolts and lift up the engine a bit. 👍
Sorry to bother you again is it 3 mou ts you need to u do one at the front behind radiator one under Battery case and one at the back behind gearbox thanks mate having real problems with this it's the most awkward suspension arms iv dealt with
1 hour ago, Johnnya260180 said:
Sorry to bother you again is it 3 mou ts you need to u do one at the front behind radiator one under battery case and one at the back behind gearbox thanks mate having real problems with this it's the most awkward suspension arms iv dealt with
I think it’s the only mount that is on the side of the suspension arm, in your case will be left side mount and slightly lift up the transmission. The other mounts will twist a bit. Just do carefully and if other mounts twist too much then you may need to undo another one too. Here a video from auris hybrid for reference.
Thanks so much mate appreciate the advice
You are welcome 👍
