Reversing sensor volume level is very low does anyone know how to increase the volume on them, please!
This depends on whether the sensors were a factory or accessory fit, do you get a visual display of proximity as well as audible beeps or jusy beeps?
  • Visual and audio warning means factory, which can be adjusted through menus ( depends on age ) either through the display head unit via Setup > vehicle settings or through the multifunction display and vehicle settings
  • Audio only means accessory fit there is no adjustment you will need to locate the speaker and try and relocate it to make it more audible
Hi Lee,
          I have Visual and audio warning.  Factory fitted.
Hi,  Can some kind sole please tell me where the Reversing sensor speaker is located.  I have factory fitted sensors on a 2019 H-cr.  The volume is way to low.  Front sensors are fine just the rears low.  Can I simply move the rear sensor speaker forward? or can they be ajusted?
Similar topics merged
