2022 V2 Map update
SimB
Hi all
I’ve tried to download the latest map update from the Toyota site and it appears to download correctly at a little over 13Gb as a zip file but I appear unable to unzip it , anyone having a problem
This has been discussed before. I had exactly that issue downloading using an iMac. I sorted mine by changing the software to unpack the zipped file. It was also necessary to delete and re format WIN 32 the USB before transferring the file to the USB. It worked fine after that and took about an hour to install, it needs the car in READY mode.
Hi , thanks for the reply what software did you use please
TIA
On my Mac I used Unachiver, it’s on the App Store. I simply located the original downloaded Zipfile and used the Unarchiver software. It’s available as an alternative to the Apple version by the usual RH click.
