DPF needed or not?
Rosik
My DPF was blocked and my car didn't drive anymore. Finally I found a mechanic that understood the problem, cut my exhaust pipe and cleaned out my DPF and I could drive again. The car was smelly from the moment I had a problem that I couldn't drive due to a blocked DPF. Now the car is smelly and sometimes it has white smoke. Is the DPF really needed?
Cars will work without a DFP but it will fail its next MOT if you cut it out and disregard it.
Have you cooked the hell out of the clean DPF? Hour or two on a higher revs run?
MoT fail if removed.
Car is located in European Georgia, not sure if MoT will fail. The RAV4 is from November 2007. I couldn't find any engine code. Where can I find it?
It is listed as a D4D without DCAT. I found some other codes near VIN ALA30L-AWFGRW
You do not have a DPF then, it will have a catalytic convertor, it will fail emissions if you have them in your country, it may also cause the engine to either under or over fuel
the inside of a cat looks like a honeycomb made from a ceramic
You need to ask about emissions tests in your country. It used to be a common thing around Europe to remove the DPF but gradually countries’ laws were changed to make it illegal / a fail.
Your white smoke might be unburned fuel as it often is with the DCAT but if you don’t have that system then I’m not so sure.
