Handbrake light staying on just very faint.looked at switch ok.unpluged wire stays on just.any ideas.
Handbrake light often doubles up as the brake fluid low light.  Check your fluid level.
  • Like 3
Fluid ok clean wires all ok thanks.
Its possible its picking up a small discharge from other components you can spray it with a electric sealant to keep the damp out.
Could the light also double up (or treble up I suppose?) as a brake pad worn inducator?
