Help and advice please toyota yaris cross airbags deployed but braking power low displays
Do you have a code for yaw rate undone ?
Calibration
Enter Dealer Mode (Calibration) and clear the memorized steering sensor zero point, yaw rate and acceleration sensor zero point and system information, and then perform yaw rate and acceleration sensor zero point learning and system information memorization.
When I look on live data says yaw rate undone
I will take screen shots will do in 20 mins
I go in to brake epb calibration  I don't see any option for dealer mode
Open TS and run a health check, what codes do you have
Ok doing it now
Clear the RoB and try a calibration in ABS - Utility
Still same
Clear the RoB
ABS - Utility - Reset
Abs - Utility - Test mode
Try it from srs - Utility -
have you tried a zero point with the autel
I tried exactly that both with techstream and autel . Just don't seem to work when looking at live data I can see speed on each wheel sensor.  But when I look at live data stationer says out of controlling to everything... what I've read says I shoukd drive it at 12 mph with brake switch off u heard of that ?
Yes, clear the C052f14 take it for a drive (do not have the scan tool plugged in)
Ok just to let u no the code never clears its instantly comes back
Used or new ABS pump ?
It dont allow me to see anything
it's a paid service, if you have a genuine techstream subscription access to TSB's is included
I keep getting error but I'm logged in
Anything new to what I've tried already
idk its a paid service, i do not have a current subscription
Active test abs pump can be heard brake booster nothing just hazard flash fast for few seconds
Did you have a look at that TSB ? did you save the PDF ?
Right I managed to log on and indeed it's in fail safe mode .how ever it did also say when preforming brake calibration to have door closed and drivers seat belt on will try that .also to drive the car 20mph +
