Help and advice please toyota yaris cross airbags deployed but braking power low displays
That goes for most calibration/setup that you have the doors closed and handbrake applied
seat belt on, is a new one
Just out of curiosity how do I enter dealer mode
Says signal check (dealer mode)
Dealer mode = Utility
Still same my only other option is to drive it and see if that helps
A few pages back i did say to you, you needed to drive it, that is part of the self test system for the ABS what i assume you had done already
I drove it10 mph before but clearly its not enough I will fit headlights tomorrow and take it for a 10 min drive .... if this works I'm going to give u a big drink
UPDATE all lights all fault codes gone 28 mph reset the system
Only thing is I can't hear the brake booster at all and no fault codes recorded for it .. and when I do calibration lights blink but for how long as they keep on blinking until I turn ignition off and on again but no faults recorded
zero point calibration just follow the on-screen prompts once it's done it tells you what to do, do the brakes work as they should, not 100% but the systems don't use a servo like previous gen hybrids
No fault codes tho and no warning lights on dash board door closed seat belt on rest memory then ignition off then on again hand brake down and click next abs and skid lights flash and they just flash and flash I left it even for 5 mins car breaks fine just don't hear the brake boodter when pumping the brake pedal like my other hybrids
Ok so I'm satisfied that if there was a malfunction it would be stored .. the new brake design just can't be heard like my prius or chr ..
And u have been amazing help do u have PayPal
No problem, glad you got it sorted, no payment required
this new generation tech is a bit of a learning curve
This has been the best topic that I’ve followed in the owners forum so far.  I have no electrical knowledge or experience but I really enjoyed the interaction between Abs and Bob.  It’s great that the problems have been resolved and Abs now has a fault free car.  Great advice and patience from Bob as well.
  • Like 5
Bouncing ideas of others always helps, there is a lot more tech in these newer cars, things are getting more complex, you're stuffed without dealer level tools
I agree totally
  • 1 year later...
On 11/11/2022 at 12:23 PM, Abid ABS said:
Update i coded the srs module airbag light has cleared how ever only issue the abs is still in fail safe mode same code brake power low abs malfunction secondary brake malfunction parking brake malfunction
C052f14
Hi Abid hope your doing well is there any I can contact you i have the same issue with my 2022 Yaris it is stuck the hand brake is on and is has been involved in a accident and it has all the brake warning issues and will not move
Send him a personal message.
Press and hold the P brake button down for 30 seconds it should release, the car needs to be driven to charge the ABS charge capacitor (black box under the passenger seat)
If the parking brake will not release, disconnect the motors you can then apply 12v to the motor to wind them in/out
swap polarity to change direction
if the airbag or pretensions have fired, you need to get the SRS cleared/replaced
I assume that the car goes into ready mode
