navigation communication signal and camera
JAJSON
I disconnected the navigation module as you wrote. But it didn't help. the pin still gives no tension. But I have noticed that a lot of things change after disconnecting. interface looks completely different, doesn't show my language, i also think bluetooth works better. Previously, when I listened to music from my phone, it did not always show me information about the music, but now every time
If it's just missing the 6v you can use an external voltage regulator, use the 12v from pin 2 on the 28 pin connector and a ground
A suitable regulator will be a L7806 or LM7806 12v in, ground, 6v out, insulate it with a piece of heat shrink
