Sat Nav
Derek.w
Since iPhone was updated and car was serviced with ecu softwear update I noticed Apple maps are starting up when phone is pluged in and you press the map button on the multimedia system.
It will also start up if you press the map button providing bluetooth has not completed loading then again sometimes blutooth and releted items do not load when its pluged into usb port but not always.
