Bosch spark plugs
Hilton Africa
Hi, which Bosch spark plug do I fit into my Toyota Auris 2012, 1.3? It now has 183693 km on the clock. Please advise
Assuming you mean the 1.33L engine then I would only fit the current recommended plugs from Toyota. In the UK the specification was changed to a hotter plug a few years back.
I've heard of reports of poor running with alternatives.
Factory is Denso, they tend to run much better on the Denso plugs, especially the 1.33
If this is a South African car, specifications can vary a lot
Original plugs would have been 90919-01253 which where Denso SC20HR11 Toyota/Denso have since replaced these with 90919-01275 which are Denso SC16HR11
Yes, SC16HR11 is 1 step hotter than the old plugs. It is probably from the obvious reason that many 2010-2012 Prius owners have oil burning issue and hotter plug helps the misfire issue.  I always stick with whatever OEM or revised version per OEM supplier recommendation.  So only Denso, nothing else.
