Check engine light and check 4x4 light on the dash,
Phillip Roberts
Check engine check 4x4 system light, error code p0488 on obd, EGR cleaned, lights still on any ideas please, Rav 4 2010 d4d xtr
Yes car is running superb, just check engine system and check 4x4 light on,
Hi Phillip,
I'm not familiar with the Rav4 4x4 D4D but have had lots of problems on other vehicles which those lovely EGR valves. I'm sure that someone on here had problems with similar codes and the EGR system and it turned out that the exhaust manifold was blocked internally. Think there are small passages within the manifold that get blocked and can only be cleaned properly if the manifold is removed first and then cleaned out thoroughly. Not always enough to just clean the actual EGR valve itself. You may find something on youtube on this if you search.
Having said that there seems to be a miriad of causes for the p0488 code bringing the MIL on
Thank you Derek Ha, its going on diagnostics tomorrow so should shed some light, thanks again, got to say though it's still running perfect just those damn lights
Had the diagnostics done, and it's fixed, I would like to share with all, that it was a faulty diesel throttle body gear, just in case someone got same prob,
  • 6 months later...
Hi All.
got a 62 mk3 dcat 70k miles diesel Sr.  Just got same problem after filling up at Tesco ?  Getting a judder auto changing between 1 & 2 !  Been fine for over three years !  Ambient temp for last three days has been 30 deg C,  it's been parked for hours then used for a few ?  The car is used most days and at least one 80 mile run a week !  Not a sucoobie do !  Any geniuses  out there ?
Bucket of fuel and soak over night?
Hey I was looking at this same forum looking for answers. Almost changed my throttle body but my mech said no first open the inlet manifold. And I did and man oh man was it nasty. Got the manifold the egr and the throttle all shot blasted and fitted it back all errors gone. Pain in the butt was the air pipe from the bottom into the throttle. Still need to put a jubilee clip back on it. Uploaded vids to tktk Kewl tings
The judder from the gearbox is accompanied with this error. And also I forgot to mention the possibility of the gear going is still an option but as both the egr and the throttle have gears inside. My throttle however was rivetted and luckily it seems to be fine. My egr valve electronic gear inside seemed ok.
On 6/13/2023 at 6:21 AM, Machloop said:
Hi All.
