Accelerator dead and no power to instrument cluster
Ok gotcha!
OK so AM1 and IGN have 12V from the fuse terminal but IGN-ECU (fuse 30 in drivers footwell) has no voltage.
Do your brake lights work ? Any power to the OBD2 fuse ?
Brake lights do work, will need to check the ODB2 fuse signal.
I think the IGN-ECU is a red herring, it isnt used on my car model.
It must be relay related main power or acc, you should be able to feel them click when you turn the ignition on
Can't seem to find the relays. Which ones would I need to look for?
I'm hoping the ecu isn't faulty.
19 hours ago, Dnalevy said:
Passenger side behind the glovebox 4-5 blue relays, iirc it should be R1 and R4
you should be able to swap the relays R1 with R2, R3 with R4
Switched the relays with 2 and 3 (fog relays), no difference.
Forgot to mention that the radio has no power!
Obd2 fuse is AM-1 which is getting power
22 hours ago, Dnalevy said:
Actually obd2 is also under driver footwell. Checked it and getting power.
 Remove R1 main relay  test to see if you have 12v on pin 1 or pin 2 with the ignition on
I suspect your multiplex network body computer, aka BCM, has partly failed. The BCM is part of the above fuse box
