Toyota alphard cutting out, vsc light, traction light and car with exclamation mark in red
Hi everyone I have a 2007 Toyota alphard the car was running great for a few months and we thought the aux Battery was dead, so we went to our local parts supplier and bought a exide Battery which I believe isn’t stop/start Battery, the car keeps cutting out after so long and won’t start again for another 10-15 mins or so or disconnect the battery and connect it again and it will fire up. We have red car warning light on with exclamation mark in the middle, vsc light on, traction light on and cruise control doesn’t work.
we have bought a battery from Toyota directly as we got told this battery will definitely work for this vehicle but it still isn’t a stop/start battery and we are still having the same problem after 10 mins of running the car.
has anyone had this problem before and how did you fix it or does anyone know what is causing the problem as we got told it was the battery but it’s had a new battery from Toyota directly
Weird, this has just happened to me today as well, first time. Apparently its hybrid system fault, I don't know much more than that so far, I've ordered a obd2 diagnostic to try and get the actual fault codes.
