Did any of you ever see a replacement button set so you could move the window down with a single push?
Probably not just the buttons alone but also a chip, I guess...
Not yet, Aliexpress is the best place for such items.  I replaced my Rav4 window controls with ones that where illuminated and were excellent.
Again, these are not yet available, will no doubt soon will be.
To be honest, I've never came across any that convert the hold push button to a one touch button !!
Known as auto windows, or one touch windows, it's usually a module you need to wire in, i thought the late mk2 Aygos had this on the drivers side
The Auto feature is usually a 2 position switch in each direction, but it can be done with a standard switch, i did the passenger side on my yaris, just the rears to do
