toyota yaris 2019 cable dab+ to kenwood8020dabs dab+
misterio1981
good evening,
I had a kenwood8020dabs built into my toyota yaris 2019
here was a touch2 with dab in it.
now the problem is that the plug of the toyota yaris does not fit the dab+ on the kenwood.
does anyone have a solution for this, using a cable?
The Toyota connector is an SMB in a Toyota housing, IIRC the Kenwood uses an SMB,
you should be able to unclip the plastic housing (remove the lock clip) and plug it in to the Kenwood
the Toyota OEM connector is a Sumitomo HFC III
https://prd.sws.co.jp/components/en/detail.php?number_s=60987445
So i must remove the white clip and then i can remove the plactic house? image.jpeg.f6e57983021dbd5d3a73cd28de689d33.jpeg
yes, there may also be a little tab you need to flick up in the back
