AYgo cluster indorcator arrows not working
Hi all dose anyone no why the green arrows in a 2010 aygo  aren't working hazzard button and indorcator stalk are working .. lights are flashing on the out side but the arrows are not could this be the led in the cluster strange as both are not working
Yes more than likely dead LEDs or resistors but dont rule out the stalk
As flash says most likely the speedo LEDs a common fault with Mk1s as is main indicator stalk. The green arrow LEDs should also flash when hazard lights/switch on and when using remote locking if you have it, so might aid your diagnosis.
Silly question, you haven't replaced the bulbs for LEDs ?
