Day time running lights
Derm avensis
Hi, I have a 2012 avensis and on one side the drl bulb and LED strip is not working, the bulb for the drl isn't blown, can anyone help ? Or know which fuse to check ? Thanks in advance.
Have you tried with a new bulb? The bulb is T20 (7443) with two filaments.
The led strip across the top is gone as well, both went at the same time
19 hours ago, avetoy said:
The led strip won´t work if the parking light is broken (=5W filament in the drl bulb).
