Setting clock time on Yaris Cross
MikeB2
I know this might come across that I am a bit dumb but I want to set the  correct time on my new Yaris Cross with Tech Pack/smart connect screen. I have gone through all the menu options but nothing showing to change the clock. The only setting is to reset the minutes to zero which is pretty useless in my opinion. Any input would be gratefully received
The long answer is buried in the manual, the short answer is,
A short press on that menu will set the minutes to 00. But a long press will bring up the menu to adjust Hrs & Mins
  • Like 3
If Apple and all their rivals can automatically update times on their devices, why can’t Toyota, VW and all the other major manufacturers do likewise?
My C-HR with Smart Connect automatically adjusts the time - I'd be surprised if other Smart Connect Toyota / Lexus products didn't also.
Have you got a working My T account & all your Smart Connect features registered & working?
On the Corolla a quick tap on the clock takes you to the clock settings.  Is it not the same on the Yaris?
Many thanks for your reply, I adjusted the time in seconds (pardon the pun) Why doesn't the manual make it clearer? At least I know now how to adjust come the time for daylight saving hours etc.
