yaris deisel 2007 replacement glow plugs are to long!
Martin Smith
Ordered a set of glow plugs for my 4d4 engine and found them to be too long and not able to seat in. Ordered a set of NGK from a parts supplier useing the reg on the car, again too long. Any ideas as to what I should be ordering.
Can you pm me the VIN
what the part numbers of the ones you have already ordered
Edit. OEM should be Denso for an 07 it should be
19850-0W010, Denso  DG-240 160mm long
11/2008 onwards
19850-33020, Denso DG-659 156mm long
the engine may have been changed at some point
