My '99 RHD Startet (P90?) has a hole in the passenger side head lamp. It's about 3mm and a 10-15mm domed piece of glass has broken away behind the hole and is loose inside the head lamp.
Can anyone advise whether just the glass lens in replaceable, and if so what part number I should be looking for? I've so far only found complete assemblies that are £150+.
It will be a complete headlight - P90 is a Yaris 2005-2011 - the Starlet is a EP91 on a 1999
oem LH headlight is 81170-10770, 01/1996 -07/1999
https://www.ebay.co.uk/itm/234106638898
Brilliant, thank you.
I've bought that eBay listing. I can relist the one I don't need to offset the cost.
