I'm hoping someone can help me out here, I have a 1990 JDM corolla FXZS with the 5HFE. I'm needing a new left side cv axle, I've checked with megazip and Amayama both of them are telling me the part is discontinued. Does anyone know if this part has been replaced with another or if it's the same as the USDM?
Part #43420-12083
Part #43420-12083
Those might be different and best to use this website https://japancars.ru/index.php?route=catalog/toyota
to locate both models and compare the part numbers and specs. If the same then you are ok to exchange.
Good luck
Can you pm me the vin/frame number, with or without abs ?
PM sent @flash22
AE91, 5 Door 1.5 Wagon, Built 03/1990
oem comes up with, 43420-12083, sub numbers 43420-12090 or 43420-12091 I will need to double-check that on the full EPC
it looks like the inner and outer are available, but not the complete shaft
a quick look your side of the pond
Cardone 661002
Direct from Toyota
SHAFT ASSEMBLY, FRONT DRIVE
Part Number: 4342012083
Supersession(s): 43420-12083; 4342012080; 4342012082; 4342012090; 4342012091
Cardone 661002
On 12/16/2022 at 12:56 PM, flash22 said:
Direct from Toyota
This is great Info, thanks! Are the inners and outer OEM? I did see the cardone ones available on rockauto with the matching part numbers, but I have seen alot of bad reviews on the brand.
That is a complete shaft, sadly the aftermarket is full of Chinese carp like Cardone, BWD and a lot of Dorman, the forum is uk based so not up to speed on the US supply chain
