I brought a 1991 hilux surf back with me from overseas, I was having some issues and had a retired toyota master mechanic look at it. He said that I was loosing compression from the number 2 cylinder. I want to purchase a rebuild kit, I was not sure which one was the correct one looking online. Could someone give me a link to the kit I need. It is a 3.0 litter v6.
You will need to strip it down to find the issue if it's rings you will need it honed/rebored then all new rings maybe pistons, you can't just slap parts in it, it needs to come apart and be measured if it's the head(s) and or block they will need to be skimmed, burnt or destroyed valves it's a head rebuild, if the engine is worn it may need a crank polishing or ground with new bearings it soon adds up you could easily put £3-5k into the engine
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
