Milage
Max_Headroom
I hope someone here can help as this is doing my head in - (probably a very easy explanation) 😀
I have posted the three screens in the order they appear i assume the first shows the average MPG and speed and time spent driving for the current journey, the second one is the one i need help with  and the third  i assume is the average MPG for a long period (and miles left before a refuel is required)
1.thumb.jpg.5b15a9b6d118ec357e617110ab039328.jpg    2.thumb.jpg.ff8dab9aa5b2759d5874e72f0c662d18.jpg   .3.thumb.jpg.c2ff9bd7630c844b240ffbb1754bda59.jpg
Thanks, i have never reset it does that mean it could be the average since new if no one else has?
That's what I would assume! But I feel it should be higher in that case... :g:
For non hybrid it’s ok in current cold weather, even is good 👍
For the trip meter to work and show more accurate numbers best to reset after you refill full tank, then drive as usual and when your tank is low refill again and see if the real consumption matches the dashboard. More miles you cover closer the numbers will be. , perhaps you can drive for at least 200 miles before refuelling again. 👍
  • Like 3
When i first got the car and i was doing a lot of long drives on dual carriageways etc  i am sure i posted i was getting 48 mpg i do a lot of short journeys which has probably dragged it down.
Yes.
Hmm. Cumbria ... not the warmest or flattest place in the UK, so it might be reasonable for a Mk3.
Quote
Quote
I took this earlier so i was in the ball park with my earlier guess  😉
Second shows averages since trip meter was reset and third shows range to reserve and average mpg since you refilled the tank.
