Break pads and discs
Burton
Hey guys where is the most decent place to get these and reasonable? Its a 2007 d4d 2.0.
Personally, (in particular this time of year and because of mail/train strikes), I never order things like this online, I use my local motor factor.  If they are supplied wrong you can just pop back and exchange. Prices are as competitive these days as online I find also.
well i put motor factor bread disca and pads in my last car and those off brand i always had a problem them warping thats why i have to say with this new car i got toyota im always going to put genuine toyota break pads and discs here is the ones i got im not sure if they fit yours but this guy i got mine off are genuine toyota parts from a genuine toyota dealer online
https://www.ebay.co.uk/itm/360618112329
Brake discs can not warp its just a name , but they do get DTV and it’s caused by improper fitting. Any brand disc or pads can be good or bad and it depends how they been fitted. Best is to clean hub surface from rust and dirt to bare metal equally all around and dry fit everything with only lube used on slider pins, silicone grease or red rubber grease. 👍
well i was not sure what was wrong with my car as i did the breaks and was all well loobed up and put on right making sure everything went on great but my new discs (motorfactor ones) kept warping .tbh this is why i kina god rid of my car as was scundered in the disk getting warped when tbh i looked after the car and never gave it crazy hard breaking. well i have my toyota now 2 years and i dont have that break problem. i bought new genuine discs and pads for the front and i have not put them in yet as when i got the car my friend that got the car for me from that  british car auction it need new front break pads he put new ones on and well she works great and passes mot here. i changed my rear break pads and discs as my pads were nearly done i think so i put on genuine toyota discs and pads .plus my rear had that epb so i had to to that setup way to switch off the epb in service mode to change them then i took the car for a drive making sure the breaks worked before i switched on the epb so i did not loose center point
