Gearbox/differential drag
Members may have already seen this before!
I had my clutch replaced to cure the dreaded vibration 1500/2000 RPM it now run perfect, like a different car!
but my MPG dropped from an average of 62 mpg to 52 mpg , to cut a long story short it turns out the garage drained the gearbox to remove the drive sharft but didnt refill with the correct oil (LV API GL -4 SAE75 W)
anything else causes massive drag in the differential, had me head scratching for a while but it's there in the handbook under oil specification
  • Like 3
There are so many variables, the weather being the major one recently, a new clutch will take 3-500 miles to bed in fully
do you know what they put in it, the wrong oil can kill a gearbox, ie. gl5 will destroy the bearings - drop the oil and put in new
  • Like 3
