Yaris Aerial
estoes
I was wondering if someone has any details about the antenna for a Yaris Mk2 2008 (XP90). A branch of a tree recently broke my antenna but I don´t see any page where I can find it.
Any guess where to find the good reference?
The website of Toyota is anoying as it doesn´t help much (https://www.griecotoyotaparts.com/accessories/Toyota_2008_Yaris/Exterior---Exterior-Products.html)
HEre is what I´ve found so far (maybe is something useful for you):
https://www.ebay.co.uk/itm/114628282062
https://www.ebay.co.uk/itm/112071998626
I've got eBay ones before, usually because I needed a shorter one to fit under the garage door.
They are usually generic and come with a few fittings for different cars (different metric threads).
They are cheap so filter for UK (or you could be waiting weeks) and pick a couple that look OK for your needs. Then see if they work for you.
Thank you for the details, can you provide any link or the description of the antenna_
I was wondering if there is any compatibility issues between the different models such as Mk2 and Mk3 ones.
Split from an 18 year old topic.
The website link in the first post is to an American Toyota dealer (hence prices in $), not Toyota.
My eBay history says they can't find the one I bought for my Mk3, but this one has the same picture, description and supplier, so likely the same one:
23cm Universal Replacement Antenna Car Roof Aerial Mast with M5 & M6 fittings
This is shorter than the OEM one.
If the OEM is a 'circular' aerial then compatibility shouldn't be a problem as long as the thread size can be matched. I had a non-Toyota before with a profiled OEM aerial (like a narrow wing) but no problems using a 'circular' one instead. (Again to clear the underside of the up-and-over garage door.)
This one is fine for me but at £4.50 ish, delivered, if it doesn't work for you (due to odd reception area or something) just order another different one.
