Hello
i have some problem with my corolla 2020
yes it is under warranty but if any of you have experienced the same problem my technician can help.
the rear light is completely out of order regardless of which mode I choose, also the licenceplate lamps.
( note! All lamps are LED )
the brake light works and also the reverse light.
rear and also front fog lights have stopped working
I have tried disconnecting the Battery terminal to no avail.
I have previously smelled an electrical smell in the luggage, like something is burnt
Oops, you had an answer to your question,. Something along the wires was most likely burning and your had lost all your back lights. Could be a rodent attack on your wiring’s or if been accident repaired car not done properly. Better don’t drive and get it check asap. Likely to have blown fuses as a result too.
