Manual to automatic folding mirrors
Hi
how can I convert manual side mirrors to automatic please? Is there a mechanic or garage anyone knows of?
It's a DIY job, I doubt you will find anyone willing to do it
How easy or difficult is it?
Hi AC79, I would imagine that once you source all the required parts it would be a reasonably achievable diy job.
Did your model come with power mirrors as an option or a higher spec ?
If you have electric mirrors and want to go to auto folding you will need to change the mirrors, switch and add in wiring from the switch to the mirrors, the plugs on the mirrors may be different
a quick look shows the retractable mirrors are 2012 onwards 87910-0F150 and 87940-0F140, Switch 84870-0F030 (folding but not auto folding) if you want auto folding and an illuminated switch you will need the switch and connector from an Auris and wire it in
Auris switch, 84870-02101 or Try searching "Auris 183779" its best to get one with a connector and a short length of wiring if you can
The difficult part is to pass and join all the wires in small space
the other difficult part is to find the correct switcher with piggy tail, so joining wires will be easier
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
