Found relay on the floor
Cezar_Alex
Hello, as the title suggests, I found a relay on the floor when I got into the car today. It was near the accelerator pedal. The relay's code is VFM-11F41-Z16. Also, the car in question is an Aygo 2017, with the steering wheel on the left. Any help would be greatly appreciated.
The code seems to show a general purpose relay used across pretty much all models.
Have you had the car a long time and this has suddenly fallen out from somewhere or is the car new to you?
First thing to do is try every possible electrical function (inc horn) and see if anything appears not to function. Engine cooling fans would be one item that would not easily be checkable.
What doesn't work ?, i take it the car starts ? what colour is the relay ?
Check your tail lights, rear fog light, interior lights and rear defroster
Update: all electronics seem to work, except for the rear fog light, and I'm going to replace it as soon as possible to see if the relay has anything to do with it. Thank you all for your suggestions
The fog relay is located above the internal fuse box on the No. 2 connector holder................. good luck
click to enlarge
