Rubber door strip replacement
The protective door strip on the passenger rear door of our Carina E saloon has snapped. Does anybody know where we might be able to get a replacement one if there are available?
I believe this is the correct part number (this is the seal that sits around the door opening - not on the door itself): 62334-20010
It should still be available to order from Toyota - but do verify the correct part number as 1994 is a transition year for a facelift.
