Fuel pump relay
Covah161
Trying to help a friend. He has a 2013 Camry LE 2.4l. Won’t start, fuel pump not running. Powered up fuel pump and car runs fine. All fuses good. Can’t find the relay. Looked behind glove box, inside fuse panel and outside panel. Some say it is the EFI relay but there is none on this model. Does it have one and if so where is it. Thanks
