How much electricity does it take each time I charge my plug in hybrid?
charlie smyth
How much electricity does it take each time I charge my plug in hybrid (a plug in Prius, though absolute precision is not required and I would take info about other plug in hybrids)?  I guess it would be expressed in terms of kilowatt hours?  We do not have a special charger.  We just plug it into a regular outlet, at home (takes a long time).
I once worked out it cost me 80p for a full overnight charge, just about 2 hours 20, 8kwh. Through dedicated charging hub courtesy of Chargemaster - haven't looked at the web display in yonks.
But that was 5 years ago.
Cost has probably quadrupled at least.
It may not take longer using the kit that comes with the car.... Mind figures are for both 2018 and 2022 PHEVs
Looks like the hub has stopped data harvesting
Location Start date Charge duration Start time
Usage (kWh)
Home 12/08/2020 4 days 19:16
4.30
Home 12/08/2020 7 hours 07:43
0.00
Home 17/07/2020 a month 14:49
0.00
Home 16/07/2020 a day 15:04
2.73
Home 12/07/2020 4 days 16:04
3.04
Home 11/07/2020 a day 09:24
5.58
Home 24/06/2020 7 days 15:11
4.67
Home 14/03/2020 2 days 14:05
0.79
Home 12/03/2020 a day 10:27
5.70
Home 11/03/2020 17 hours 15:25
4.92
Home 10/03/2020 19 hours 14:53
6.11
Home 07/03/2020 a day 11:03
1.06
Home 05/03/2020 2 days 12:16
4.82
Home 04/03/2020 a day 10:59
2.14
Home 27/02/2020 2 days 07:40
0.00
Home 26/02/2020 17 hours 14:17
0.00
Home 25/02/2020 a day 11:47
6.01
Home 22/02/2020 3 days 09:16
0.78
Home 20/02/2020 2 days 14:31
0.00
Home 18/02/2020 2 days 14:55
0.00
Times given are, of course, the total time the lead is connected.
Our present RAV 4 PHEV 2020 got 18.1 kWh traction Battery and it takes about 13.5-14.5 kWh to charge from 0-100 % (so it must have some "buffert" ) . It got 6.6 onboard charger so it can be fully charged in abou 2.5 h in best case ( 32A 3phase I think)
Our former Prius PHV 2018 had a 8.8 kWh litium traction Battery and a 3.3 kWh onboard charger I think and took about 2.5 h to charge from 0-100 % but Im quite sure that it has some buffert so I guess it wont charge 8.8 kWh from 0-100% but... on the other hand I think there will be some current/charge loss/leak in the procedure 0-100 % ( as for our RAV 4) so it might land on ca 7 kWh when charged from 0-100 %
