Assumption
Tel 2
Phone Connectivity on the 2023 Cross Excel is wireless.?
My 2021 Lexus Spec stated the same but required a Dongle.
Please confirm.
Tel
Only Apple carplay is wireless, and that is with the connect system only, the rest is tethered
  • Confused 1
Tel, phone connectivity is wireless with Android phones.
I also understand that Android Auto may be wireless but this depends on your phone and not the car.
I found the original message by Devon Aygo, as you will see Wireless connectivity is used for Phone service but Blue Tooth is used for Android.:
Terry, I see you refer to a Dongle on the Lexus.  That should work on the Yaris too if your phone is otherwise incompatible.  What make is your phone?
As it happens I think wireless (BT) connectivity is only really useful if you have a wireless charging for your phone.  On long journeys a wired connection charges my phone at the same time.
10 hours ago, Tel 2 said:
iPhone 14 Pro so will not require a Dongle but will need a charge cable as the superb Apple Car Play consumes phone battery.
Tel
Which really makes wireless charging an essential if using car play etc
Yes indeed - and depending on phone type and which navigation app is used, the phone gobbles power and can actually overheat and shut down using wireless charging (ask me how I know this....) Learned the lesson, now use wired charging always for AA or CarPlay
