2007/56 plate TOYOTA AVENSIS T3-S D-4D
toolapcblack
Hi all is a 130k mileage 2litre diesel a risky buy? Does this have the same engine as the the 2004 D-4D? Belt or chain timing belt? if belt i assume its the same schedule as the older engine every 60k?
Many thanks
Any 15 year old car with 130k miles is a risky buy, but I'd say less risky than most.
That will be the newer 1AD-FTV engine, not the same as the 2004.  Timing chain not belt.  No DPF.  Mine is the same age and 160K, had it since 30K, no major issues, still drives great.  Hoping to get to 200K but we'll see.
what you think of the 2014 last of the 1adftv 2.0 engines with dpf . plus mine dont wild long runs as its way my job is and life i drive work van and car sits gets out but short drives
I have no experience with the DPF version, but I wouldn't buy any diesel with DPF unless I was doing regular long drives.
Thanks for the info boss well I guess my yoke will be the new test car 2 try see how long dpf lasts with short journeys if gives bother
thanks andymcm
yeah i bought a verso 2004 a few years ago deliberately went looking for the older engine for that one, still going strong and have heard some people get 300k out of the older engine...fingers crossed
5 hours ago, toolapcblack said:
thanks andymcm
I thought older engines had problems with cylinder linings and burning oil .they solved that problem with the newer 2.0d4d engines .I wonder what the 2014 last of the 2.0 1adftv engines are like. I hope I get loads of miles out of mine .I was chatting with taxi drivers with a 2014 2.0 1adftv angines they told me had no problems with them at all
