2007 Auris : Auto lights (headlights) sensitivity
Supaflymx101
Hi
I find that my auto headlights sensitivity is not as sensitive as i would like it to be ... ie as it gets darker its takes longer to come on.
I would like it to come on ealier when its not too dark at night. Hope that makes sense 🙂
Is there a way to change or adjust the sensitivity settings of the auto headlight settings ?
Yes, just turn the lights ON manually 👌
I don’t think you can change these settings, perhaps check the light sensor is clear of any obstructions and windshield is clean too.
Remove the light sensor cap, and paint it darker 🙂
Anyway you can experiment with it. Light sensor cap is under the windshield, there are 2 tiny caps sticking out, you will see it.
Not sure which one is for lights, so put something over it, and see if lights turn on.
