I have 2021 toyota hybrid launch edition and I am constantly having to jump start it with my Neco jump starter.
quick question, can I use the fuse box panel where I jump start it, to also use with a trickle charger.
sorry if this an obvious question?
Matt
26 minutes ago, Matt29 said:
Matt
Yes, definitely.
Thanks so much @anchorman. Is this a common fault with model?
It seems to be some combination of people getting cars with depleted 12v batteries when they collect the car and not using the car enough for it to put charge into it.
It seems like a lot of people are trickle-charging the batteries through the contacts in the fuse box just fine so far, although DevonAygo has mentioned that it's safer to do it directly to the Battery. I don't think he elaborated on why though.
I've not had a problem with mine and neither have a lot of other Mk4 owners, but there is are quite a few who have. I think the biggest difference is I and the non-problem group use the car regularly, whereas the problem group tend to only use it for short/infrequent journeys.
  • Like 4
@Cyker ok i plugged it in now. Am I going to be ok?
It’s only usually a problem with very low usage.  Have you got a Dashcam or something using power all the time?
The fuse box contact is just a wire to the Battery.  It will be fine.
6 minutes ago, anchorman said:
The fuse box contact is just a wire to the battery.  It will be fine.
However this method requires you to open the bonnet, take the cover off the fuse box, then clip on the charger leads.  This is satisfactory for jump starting but I suggest a PITA for regular charging.
A more convenient alternative is to hard wire charging tail to the Battery and simply plug the charger lead to the tail.
First fitting the tail might be daunting or awkward, but once done it is easy thereafter.
A more convenient alternative is to hard wire charging tail to the battery and simply plug the charger lead to the tail.
Takes me a couple of minutes and no f arting about under the seat 😉.  I’d also rather feed the wire out at the front than through a closed door.
Then you may need to look into replacing the Battery for peace of mind and bother. After that, the car should be use regularly or in ready mode/trickle charge if not used often.
Most of the Battery issues are from people either don't use the car very often or inherited a bad Battery from last owner. I have never had a problem with battery in over 12 cars of my driving life.
Dealer did that (Noco lead) for me FoC, really easy to plug charger in either via open rear window or some people do it with door closed and cable held in the door seals. Perfect, because in the near future, car will be left alone and neglected for a few weeks
Some people just do not care about the feelings of their car! I bet you do not even say "Good morning" to your car when getting in on a morning, or "Bye, sleep tight" when you leave it on a night. Have you got a kind relative or neighbour who can pop round just to let the car know it has not been forgotten? 😁
  • Haha 6
Lidl has chargers currently on display in stores for anyone looking for a smart chargers 👌
  • 1 year later...
They sell us cars with dud batteries. Getting mine replaced under warranty.
Yes,
the used cars that been sat for two weeks and longer will come with dead 12v batteries no doubt about it. Prior to delivery/collection of the car the vendor will jump start it and let it run( ready mode)  for some time and kindly deliver to you.
Then after you take ownership depending on luck and use of the car the Battery  may get rejuvenated and extend its life or as per most of the cases died and required a new Battery replacement.
This is the reason why anyone who had bought new or used car from a dealer and run into Battery trouble should pursuit the dealer who car was bought from to replace battery under warranty according to the consumer rights act 2015.
There are also another examples that first owners do exactly the same thing when they need to return their end of lease or part ex their cars for a new one. They know that their batteries are dead, they jump start the car or recharge the night before they return the car to a dealer, get the new car home and leave the old car with existing battery problems to the dealership. The dealers then pass the battery problems to the next owner. However they are obligated to replace under consumer act as above because they do charge minimum of 25% more than they had paid in trade value. , plenty to cover a new battery £80-£170 . 👍 Stand for your rights. 👌
