got a new dash cam
stacy stacy
HI, i've done some research online, but still not sure if i have to unplug the car charger from the cigarette lighter when leaving the car?  I'm worried about flat Battery.  Hope to hear some clear answer, hopefully 🙂 🙂 thank you!
When you switch off you should see the Dashcam shutdown.
This confirms that the ‘cigarette lighter’ power socket is powered off too.
You'll be fine - The ciggy socket is ONLY powered when the car is on, so no chance of anything plugged into it draining the Battery when the car's off.
