Hi there
I have a 2004 Toyota corolla automatic VVTI T2. It has an issue with the indicator not working on the dash and lights outside. I have checked the hazards and they seem to work. Please can you advise what the issue may be
if the car has not been used for some time the grease inside the stalk goes hard, ignition off, work the stalk up and down a ton of times and see if it comes back to life
even tho the hazards work, it could be a relay fault
